Equinox coolant leak
https://cimg7.ibsrv.net/gimg/chevrol...03bed3ed2.jpeg https://cimg3.ibsrv.net/gimg/chevrol...9e9bc90a8.jpeg https://cimg5.ibsrv.net/gimg/chevrol...e5fde1be5.jpeg https://cimg1.ibsrv.net/gimg/chevrol...48856ab5f.jpeg https://cimg8.ibsrv.net/gimg/chevrol...f39beb0be.jpeg https://cimg0.ibsrv.net/gimg/chevrol...de03624c9.jpeg My wife has a 2008 LS Equinox with an external coolant leak. I pressure tested the system and it held psi, however I spotted an active leak on the driver’s side of the engine block. Pictures are attached- I’m leaning towards external head gasket leak. Upon start up there is white smoke from the tail pipe, however it goes away after 30 seconds. No evidence of coolant in the oil. Any ideas? |
It looks to me like the lower intake gasket is leaking. I don't think the white smoke is anything to be worried about. The lower intake gaskets don't fail very often on the 3.4L/3400 in the Equinox/Torrent. They use different design that is better than the 3.4L/3400 used in other GM vehicles (which did have a high failure rate).
Originally Posted by Saaber6
(Post 415570)
Originally Posted by John Carter
(Post 440640)
Hey thx for the pics did you figure out the problem? I think my 2007 equinox has the same type of leak any help much appreciated
it will mix up better. |
(Post 440640)
Originally Posted by JoeandRachael Howard
(Post 461467)
I also have the same leak on my 07 equinox. Have you heard any idea where the leak is coming from? I'm having an issue with bleeding the air from the coolant constantly it seems like. Thinking this could be because of the leak drawing in air as well. Thanks
