how to fix noisy lifters or valves - Chevrolet Forum - Chevy Enthusiasts Forums
Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
Old March 11th, 2018, 7:02 PM
Default how to fix noisy lifters or valves
I purchased an 06 equinox with engine noise and some signs of oil in coolant, I have repaired this before on other GM engines doing intake kit and engine flush. This time I replaced all lifters and intake gasket kit re -torqued rocker arms. While this did reduce the noise it did not cure it. At idle it is very loud at about 2000 rpm it seems quiet but can still hear noise but is more of a fast ticking noise at higher RPM. My question is what is most likely the problem at this point and what would be best suggestion for repair?
BTW there are no engine codes and other than noise engine runs smooth
kheintze is offline
Old March 12th, 2018, 3:27 PM
kevinkpk's Avatar
Ok, general rule of thumb, with the piston at tdc, both valves closed, run the rocker arm down, and back it off to .010".
kevinkpk is offline
Old March 12th, 2018, 4:16 PM
to clarify do you mean leave .010 between rocker and valve stem and is this for the 3400 with roller rockers or just in general for any engine.
kheintze is offline
Old March 12th, 2018, 4:56 PM
kevinkpk's Avatar
The rocker arm be it roller or push rod, general rule of thumb .010" feeler gauge between it, and the valve stem.
kevinkpk is offline
Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
