No sound from speakers
#21
Attn: Chevrolet Motors
So I am wondering why so many other customers have asked the same question in the only response that GM Chevrolet can come back with his have you contacted your local dealer?. Answers would be nice.
#22
No Volume on my Stereo
Instead of asking me if I contacted my local dealer, could you please answer why I do not have any volume coming from my stereo system in my 2005 Chevy Equinox? And could you reply with the answer of how I can fix this why should I have to pay a dealership when I paid for this vehicle? You figure it out.
#23
If you want help on here, we need more info. Have you checked any fuses or done any other troubleshooting? If your Equinox has the subwoofer in the cargo area, your factory amplifier is probably bad. Unfortunately, this is a somewhat common problem, and the OEM part has recently been discontinued. If your factory amplifier is bad, you would need to find one from a junk yard, and it must be from a 2005 Equinox. The 2006-2009 models use a different part. if you are skilled in car electronics or know someone that is, you could replace the factory amplifier with an aftermarket 5 channel amp.
#24
Check the Amp under the passenger side of the rear seat, it may have failed. Unfortunately, I don't know if anyway to test it, I only replaced the one I had on a suggestion form another tech. My Equinox did the same thing, the AMP fixed the issue. It was not cheap, even though I got a used one.
#25
I have a 07 Equinox my issue is I get a crackling noise from the speakers even when the car is off.
it is a lt with the pioneer premium sound system.
Would love to find a fix for this
#26
Does it get louder when using the stereo like normal and turning up the volume?
Do you still hear your warning chimes and turn signal clicks from the speaker in the driver's door?
#27
I had this crackling noise but from only the passenger front door. Now I have no sound from any speakers except the passenger front. No warning chimes no turn signals nothing please help
blawson
Sonic (Aveo)
October 9th, 2019 9:55 PM
Chevyowner218
Equinox
14
October 1st, 2013 11:19 PM
