overheating
I think what you meant to say was that the engine overheats when idling at a stop, but runs fine driving down the highway. If this is the case, your cooling fan is probably not running.
If you have a 2005-2009 model, try unplugging the harnesses going to the cooling fans and reconnecting them. Those years have a tendancy to develop a weak connection there. In some cases, enough heat is generated to melt the plug.
