Rear Turn Signal lite but does not flash
So my rear turn signal light no longer flashes when I am changing lanes. I just figured that the bulb burnt out but the bulb is still good. Does anyone know what I need to replace in order to get this working again. Is this the turn signal relay and, if so, where is it located and where can I get a replacement part?
You probably have gotten this fixed by now, but I thought I would post for others looking into this.
Are you sure about it not being the bulb? Some bulbs may have one or two filaments. In two filament lamps, the smaller of the two is for the tail lights and the larger is for brake lights, turn signals or a combination of both. The steady light you are still getting from the bulb is most likely separate from the flashing of the bulb. Good luck!!
Im having a similar issue
ive looked a lot into this but my main problem is that my left 2 blinker lights are not working. The right side are though and every other light for that matter, just not the left 2 blinkers.
ive checked fuses, bulbs, tested some wires behind connectors, checked like 3 grounds. Help!!
Besides any fuses, there may also be a turn signal relay. Sometimes, it is located in/near the fuse box, but not always. Did you perhaps check/replace that? You also mentioned that you tested some wires. What did you conclude (i.e. - was there any power going to these wires when there was supposed to be)? And does the left side work at all when you turn on your hazard lights?
Official GM Rep
Very sorry for the continuing concerns! I can definitely understand how frustrating this may seem, but if you do need the dealership's assistance, we can certainly reach out for you. Feel free to send us a private message if the additional help is needed. We look forward to your updates.
Patsy G
Chevrolet Customer Care
L1NK1NP4RK
May 19th, 2012 6:49 PM
RomanGuzi
October 2nd, 2011 11:40 AM
J-Narz
Avalanche
May 1st, 2011 6:21 PM
