2007 Equinox Stereo Wiring Diagram
I just bought a 07 Nox LS. Once I got it home I noticed that the Rear Speakers don't work. I took the radio out and noticed that the 16 pin plug was gone and the wires were just hanging there. I went to the dealer and they ordered the plug for me. Now that I see the connector I image there will be some kinda of pins that I will need to put on the wires so they can slide into the plug and be locked into place. The issue is that I don't know what wires go where in the connector. Can someone tell me where I can find a Wire Diagram for this? Or can someone help me out with this? Any help is greatly appreciated!
Ps - No Bose or OnStar |
1 Attachment(s)
Thank you so much for the reply!!
So am I reading this right.. Left R + = Brown to Pin 5 Left R - = Yellow to Pin 13 Right R + = Dark Blue to Pin 6 Right R - = Light Blue to Pin 14 |
exactly right
shawnvw,
I'm having issue with my local GM dealer. My girlfriend went in and asked them if they had the pins that fit in this connector. They told her to stop back later. She then went back and they took her number and the VIN. We didn't hear anything for a day and she stopped back down and they said they have 15 boxes of pins and that they were going to charge us $100 to find the correct pins...would you happen to know what pin this would take? Is this really a big issue or are they just pushing us around? |
Radio C1
Connector Part Information •OEM: 7283-4490-30 •Service: 88988743 •Description: 14-Way F (BK) Terminal Part Information •Pins: 1, 8 •Terminal/Tray: 12191812/19 •Core/Insulation Crimp: C/A •Release Tool/Test Probe: 15315247/J-35616-2A (GY) •Pins: 2, 3, 9, 10, 4, 5, 6, 6, 7, 13 •Terminal/Tray: 7116-4618-02/14 •Core/Insulation Crimp: Pins 2, 3, 9, 10 - See Terminal Repair Kit •Core/Insulation Crimp: Pins 4, 5, 6, 6, 7, 13 - P/P •Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU) Radio C1 Pin Wire Color Circuit No. Function 1 RD/WH 2040 Battery Positive Voltage 2 TN 201 Left Front Speaker Output (+) 3 TN 1875 Right Front Speaker Output (+) 4 YE 7145 Communication Box Mic Output (+) Signal (UE1 w/U3U) 5 D-GN 7149 Communication Box Mic Output (-) Signal (UE1 w/U3U) 6 WH 1487 Amplifier Enable Signal 7 PU/WH 1382 LED Dimming Signal 8 BK/WH 1551 Ground 9 GY 118 Left Front Speaker Output (-) 10 TN/WH 1985 Right Front Speaker Output (-) 11-12 -- -- Not Used 13 D-GN 5060 Low Speed GMLAN Serial Data 14 -- -- Not Used |
Charlie,
Thanks for your post! This looks like what i need except its for the 16 pin connector. Do you have this info for the 16 pin? Or is it the same pin part number? |
Radio C2
Connector Part Information •OEM: 7283-9076-30 •Service: 15136073 •Description: 16-Way F Kaizen 0.64 Series (BK) Terminal Part Information •Pins: 1, 2, 8, 9, 10, 5, 5, 6, 6, 13, 13, 14, 14 •Terminal/Tray: 7116-4618-02/14 •Core/Insulation Crimp: Pins 1, 2, 8, 9, 10 - P/P •Core/Insulation Crimp: Pins 5, 5, 6, 6, 13, 13, 14, 14 - See Terminal Repair Kit •Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU) Radio C2 Pin Wire Color Circuit No. Function 1 BN 367 Remote Radio Left Audio Signal (+) (U2K) 2 D-GN 368 Remote Radio Right Audio Signal (+) (U2K) 3-4 -- -- Not Used 5 BN 199 Left Rear Speaker Output (+) 6 D-BU 46 Right Rear Speaker Output (+) 7 OG 1406 Remote Playback Device Left Audio Signal 8 OG 5748 Radio Audio Mute Signal (U65) 9 TN 372 Remote Radio Left Audio Signal (-) (U2K) 10 GY 388 Remote Radio Right Audio Signal (-) (U2K) 11-12 -- -- Not Used 13 YE 116 Left Rear Speaker Output (-) 14 L-BU 115 Right Rear Speaker Output (-) 15 L-BU 1405 Remote Playback Device Audio Common Signal 16 -- -- Not Used |
Hi Charlie,
I like your posts about the diagrams, shows alot. My issue is with my 07 aveo, I have both the c1 and c2 connectors, the wiring color is different and some are in different pins than what the diagram shows. Any way of finding out what color goes to where for me? Yes, I'm a novice. Hish |
Hi I'm looking for a amp wire diagram for the 2007 equinox with the 7 speaker pioneer system
thank you |
| All times are GMT -5. The time now is 1:44 AM. |
