2010 Chevy Equinox transfer case fluid
Okay guys what goes in the transfer case 2010 Chevy Equinox all wheel drive do I put gear oil in it or is there something different was told to use 75 90 synthetic gear oil
Your owners manual specifies that p/n 88861950 should be used for transfer case fluid. There might be an aftermarket fluid available that may work, but I couldn't find one with a quick Google search. The little bit I did read seemed to indicate that it actually is a special fluid. The 75W-90 synthetic fluid seems to be OK for 2013+ models, but the 2010-2012 Equinox/Terrain uses different fluid in the transfer case.
I show that transfer case as a GETRAG 760 which has a 0.8 liter capacity of SL136 lubricant you can call your chevy parts dept but it seems to be a synthetic axel lubricant SAE 75W/90
ACDelco 10-4006 Synchromesh Manual Transmission Fluid is what you want. Valvoline and Royal Purple have similar lubricants too.
desert chevy
February 12th, 2010 9:16 PM
