Auto stop/start issue on 2018 Equinox
#11
Similar issue with 2019
Took mine to autozone first to check the battery. They say battery is fine. Took it to dealership. They say the amplifier needs to be replaced and that will fix the popping and the “service brake assist” message I keep getting periodically. Said that will cost around $900! Batteries aren’t cheap but are cheaper than replacing the amp. Any thoughts on replacing a battery I’ve been told is good already? Could it still be the battery causing the problem?
#12
Your stereo is powered by the alternator. The battery just starts the car.
Popping could just be loose/broken wires.
Avoid stealerships. Find a good independent mechanic.
BlueOx (December 28th, 2023)
#13
the popping doesnt bother me as much as the service brake assist message. I got a different message when it did an autostop/start a week or so ago that the dealership says was also caused by the amplifier. They’re saying it’s all related to the amplifier, which seems weird. I would think it could be a wiring problem but wouldn’t have thought replacing the amp is the answer. Just odd all the way around and was hoping it could be something easier ( like the battery).
#14
#15
#16
#18
There are at least two buses. One for critical stuff like engine and braking. One for low priority stuff like entertainment. This is done precisely so that a stereo can't kill your brakes.
BlueOx (January 5th, 2024)
#20
@anna0307 There are many, many causes for these warning lights. Running a diagnostic scan with a professional tool is needed to find out what's causing it.
You should post your own topic though please. Use the "new thread" button. Thanks.
Frankenfurter
August 31st, 2023 2:51 PM
murdockhoward
2019+ Silverado (GMT-T1)
September 27th, 2019 9:12 PM
kountzkj
June 23rd, 2018 9:57 PM
