Chevrolet Equinox
Platform: Theta
How do I fix misfiring
Old June 23rd, 2023, 7:16 PM
  #31
ap4u06's Avatar
Originally Posted by tech2
did you inspect the spark plug as mmj suggested? These years of equinox had misfires on cylinder 5 due to cracked ceramic insulator on the spark plug. this would also lead to carbon tracking on the plug wire. post a pic of the plug
not yet that is this weekends project. Going to retrace my steps to make sure everything is connected and secured correctly
Old June 24th, 2023, 2:50 AM
  #32
ap4u06's Avatar
I measure coil 1&4 ( showed 10.04) 5&2(showed 9.94) and 6&3(showed 9.78) this was all under 20k ohms settings. Any ideas ?
Old June 25th, 2023, 9:14 AM
  #33
its a waste spark system with paired cylinders...if the coil pack was bad you would have misfires on the pair cylinder also. I have an idea...check the spark plug, spark plug wire and report back.
ruley73 (June 27th, 2023)
Old June 27th, 2023, 7:12 PM
  #34
ap4u06's Avatar
So cylinder number 5 plug was loose not tight. I have checked gap on all but 2 and gap are fine. Wil have to get new set of wires bc old boots tore on me.
Old June 28th, 2023, 8:41 AM
  #35
under the tape...check the insulator
Old June 28th, 2023, 10:28 AM
  #36
ap4u06's Avatar
How do I do that?
Old June 28th, 2023, 11:32 PM
  #37
ap4uo6...at this point; replace the spark plug and wire for cylinder 5. if the misfire is gone yr good...if its still there you have ruled out a bad plug and wire.
Old June 29th, 2023, 5:53 AM
  #38
ap4u06's Avatar
very true....replace the plug..any recommendations on wire set brand replacements due to 2 of the boots tore on me?
thanks
Old June 30th, 2023, 8:10 PM
  #39
ap4u06's Avatar
I meant to ask recommendation on brand of spark plug wires and spark plugs to replace what I have in the engine. Thanks
Old June 30th, 2023, 10:56 PM
  #40
ac delco for plugs
Quick Reply: How do I fix misfiring
