Junk
#11
You didn't provide much information regarding your situation aside from it's burning a lot of oil and the stealership says there are other things wrong that require expensive repairs. You also haven't asked any questions yet, so I'm not sure what kind of help you are expecting.
Does the engine still run OK except for burning oil?
Has the dealership already disassembled and inspected the engine to confirm the damage?
It's very possible that serious damage occurred from running the engine low on oil for too long, but if the engine still seems to run okay and the check engine light isn't on, there may not be any serious damage. Excessive oil consumption in these engines is often caused by a plugged PCV orifice in the intake manifold which is what Special Coverage 14882 is supposed to address. Your vehicle should be included in this as it includes virtually all 2010-2014 Equinox w/2.4L engine. If it's not covered, your dealership should be able to tell you the exact reason why (not just "because your VIN isn't included").
The fixed the PCV problem, They would not cover it under 14882 VIN sensitive. Never run the engine out of oil its quiet. Just got it back yesterday.
My law firm I have on retainer is looking into why these things are not covered.
#12
Getting a law firm involved is a waste of time and money IMO. Your legal expenses will probably exceed the out-of-pocket costs of the repairs by the time you're done. If all they did was the PCV fix and no other repairs were necessary, you can definitely put an exclamation point on the previous sentence.
#13
There is a specific reason why your particular vehicle isn't covered and your dealership should be able to communicate that to you. If they cannot or will not do so, you should contact Chevrolet Customer Service, and they should be able to tell you.
