02 chevy express 1500 cylinder head gasket install
#41
the dipstick only had a drop of what appears to be oil.
will drain some oil and inspect.
I have been informed vortec heads are prone to cracking due to lack of clamplng force in middle of head.
I don't think I can blame dexcool for ruining metal head gaskets.
if there is just a little coolant in oil mite just reassemble and she how she runs maybe shes good for a few 100 miles or a few thousand.
seams the van body is so close to head bolts I won't have enough patients to pull head.
#45
5.7 l. Head bolts
i am replacing head gasket in my 85 c10. Ordered these Fel-Pro gaskets and bolts. Why are these 2 green thread lock bolts shorter?
They don’t grab the block threads
#46
So when you took the heads off, there weren't two shorter bolts?
#47
I've installed new mannie gasket have mannie bolts snug except the last dreaded bolt under AC bracket.
can't exactly remember where everything goes back anyone w/ image of assembled vortec in a express.
been looking closely at cylinder heads and it appears the heads can actualley be removed w/ engine in van.
so if the mannie gaskets arent the solution I'll attempt the head gasket the missfire was on pass. side head are cracks in heads usalley visable?
#48
I have installed mannie and reconnected all wires ect. engine turns over but wont crank.
I think I may have messed up the distribter any tips on lining up the shaft, I did mark the dis.cap & mannie
I've tryed to turn the oil pump w/ screwdriver however I dont think I and turning correctly it feels like it revert like theres tension on oil pump shaft.
also when I look down the hole its covered w/ oil does oil need to be drained?
