05 radiator leak
Old November 10th, 2011, 11:37 AM
ktjwillis's Avatar
Default 05 radiator leak
I have an 05 chevy express 3500 passenger van. I noticed radiator fluid leaking from the bottom of my radiator. Any ideas where it might originate? I checked all visible hoses. It is not leaking from the cap either. It is not pulling from the reservoir to keep my radiator full.
Old November 10th, 2011, 1:19 PM
kevinkpk's Avatar
You might have to pressure test the system. There is a hand pump that goes on where the cap is. AFTER THE SYSTEM IS COLD, remove cap, install pump. pump it up to 12-15 psi. Then check for leaks. These pumps aren't very exspensive.
Earth Rider
December 11th, 2012 11:52 PM
Ravenkind
July 8th, 2012 9:05 PM
99 Suburban Dad
August 30th, 2009 10:03 PM
dmhoo29
October 1st, 2008 4:59 PM
Colmustard
August 14th, 2008 1:32 AM
Quick Reply: 05 radiator leak
