1986 g20 van no spark to plugs???
i have a 1986 g20 van have fire to the dist. no fire to the plugs?
Did you pull the dist cap and check the rotor for arced or corroded contacts? Maybe there is grounding somewhere in the cap, perhaps if its cracked.
Is the dist drive shaft turning? Turn the engine over a bit with the cap off. |
