1991 G20 lower control arm
I have a 1991 G20 van and am looking for a RH lower control arm. Anybody had any luck finding one? Thanks in advance for any help
I don't believe they are available now for several years, you can purchase uppers but not lowers. You will have to get a used one from a junkyard or try Car-Part.com, an online boneyard.
Thanks I've been looking everywhere
Can your old on be repaired?
No it's wollered out where the ball joint was
New metal can be welded in there to make a new mounting area?
I have one I can sell to you. Lower passenger side, correct?
Originally Posted by oldchevy
(Post 359437)
I would not trust welding a post on there. I would be afraid that it would break off. Can you get behind the bracket, if so I would rather drill through it and put a longer bolt with a nut on the back.
(Post 474414)
