2001 express 5.7 check engine light P1345
I have a 01 express 3500 cargo van with 5.7 260,00 miles.I am getting a code p1345 I replaced the egr valve then cleared the code started it up and no light let it run for 45 min. shut it of and started it back up and the light came back on. Could this be from a bad cam sensor or crank senor?
any ideas out there? Thank You
Last edited by tkbpainting; April 1st, 2012 at 9:27 PM. Reason: spelling corrections
Professional Mechanic
Use the search bar at the top of the page. P1345 has been discussed many times. You will find all the info you need. Note, EGR has nothing to do with that code.
Ryanater
Silverado & Fullsize Pick-ups
August 14th, 2012 1:16 AM
