2002 Chevy Express Rear Differential Noise
Old February 11th, 2019, 8:25 AM
  #11
Roger1's Avatar
2500, 155", 157K
Has the 2 piece driveshaft
From the look of the cover, it looks like a 9.5/14 bolt.
As I said, I don't know jack about differentials. However, I think what you are talking about only exists on some 99-2000 express with 10.5/14 bolt. I could obviously be completely wrong.
Old February 11th, 2019, 10:28 AM
  #12
LCAC_Man's Avatar
9.5" semi-float 14bolt would require full disassembly for pinion bearing replacement, I think your mechanic is short on labor. If you have 17yrs and 157k miles on original u-joints and center driveshaft carrier you got all the moneys worth from them..
Old February 11th, 2019, 9:31 PM
  #13
StanVan's Avatar
Without being an expert, the only sure way to ID the diff is to have a dealer decode the VIN. A simple decoder like the one in the tool bar (above) doesn't give enough detail.
