2004 3500 abs issues
Old December 7th, 2017, 10:40 AM
JPerryGarage's Avatar
Default 2004 3500 abs issues
hey guys. Need some help here. Have a 2004 gmc savanna 3500 cutaway van drw. Have problem where at slow speed to a stop the abs will kick in and pulse and pull to the right. I have already replaced complete brakes all around. And the 2 front abs sensors. And it is still happening. Where should I look next. Thanks
Old December 7th, 2017, 11:47 PM
Artie1's Avatar
Try disconnecting the front wheel speed sensors individually and/or together and check if the issue disappears. That will lead you to the correct direction.
Ideally, get a Tech 2 and read the EBCM (elec. brake control module) codes. Also, you will be able to see helpful real-time data when attempting to repeat the issue - wheel speeds and brake pressure.
Old December 8th, 2017, 12:28 PM
disconnecting them separately will make the issue go away but will turn on the abs light, removing both will turn on the brake light,
There is 2 new abs sensors installed but the issue is still happening
