Notices
2007 Chevy Express 1500 4.3L clutch fan removal?
Old October 18th, 2018, 7:20 PM
Default 2007 Chevy Express 1500 4.3L clutch fan removal?
I have a 2007 Chevy Express 1500 with a 4.3L. I been trying to remove the clutch fan in it. I have the correct wrenches etc. I just need to know which way do i turn the nut on the clutch fan to loosen it? Facing the vehicle the fan rotates counterclockwise. So I am guessing that the nut needs to be turned clockwise to the right (driverside) to loosen? Really would appreciate the help. And it seems the GM service manual doesn't really mention it either. Thanks!
Erusman is offline
Old October 18th, 2018, 8:30 PM
Twscarp's Avatar
Righty tighty, lefty loosie. Counterclockwise.
Twscarp is offline
Old October 18th, 2018, 9:01 PM
Thanks for quick reply. I will give it a try tomorrow. I just find it odd that the nut will loosen the same direction the fan is spinning.
Is that because there is a reverse thread on the fan?
Erusman is offline
Old October 18th, 2018, 9:55 PM
Twscarp's Avatar
Hi, there are a couple YouTube videos if you Google it.
You are referring to "B", right?
Twscarp is offline
Old October 18th, 2018, 10:09 PM
Twscarp's Avatar
Here is a Blazer video, pretty sure the van is very similar.
Twscarp is offline
Old October 19th, 2018, 2:45 AM
My grinder and circular saw are the same. They turn CCW. If you think about it, the greatest acceleration is when the motor starts up. The inertia of the blades actually tightens it down. It's like that by design.
mountainmanjoe is offline
Old October 19th, 2018, 11:52 PM
The trouble is getting the pulley not to slide.
We took out one of the 4 small bolts and drilled a hole in a piece of flat steel. Then bolted the flat steel to the pulley. That became the pulley wrench.
canucklehead is offline
Old October 20th, 2018, 7:47 AM
I did what canucklehead said a few years ago. It really works.
oldchevy is offline
Old October 20th, 2018, 10:23 PM
Thanks guys, well it was a long fight. I just couldn't get the clutch fan off. I had to end up removing the entire water pump, with fan and everything still attached. It has over 250K miles on it. So i just decided to replace the water pump at the same time. After removing the water pump I tried to beat the crap out of the nut. Still nothing. I said screw it and I sliced a cut in the nut with a dremel tool. Finally it came off. (counterclockwise) like Twscarp suggested. Looks like the factory must have put locktite on the threads. No wonder it wouldn't come off. It was frozen on there pretty good. But finally got the new water pump and clutch fan all back on there and its working fine now. Long day started at 8am and took me all the way until 8pm until i was done. Taking breaks here and there running for parts. I appreciate all the help.
Erusman is offline
Old October 21st, 2018, 5:49 AM
Twscarp's Avatar
It was probably the right move to replace the water pump when you were in there, with that many miles. The key in your case was holding the pulley side tight, then wacking the clutch fan nut. Did you find a good way to hold the pulley side even out of the van? canucklehead's method sounds pretty good.
Twscarp is offline
Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
