2011 Chevy Express 1500 5.3l - Crank no start - Chevrolet Forum - Chevy Enthusiasts Forums
Notices
Old March 14th, 2019, 3:57 PM
Default 2011 Chevy Express 1500 5.3l - Crank no start
Well, the entire internet seems to be full of people with my same issue, but haven't had much luck getting solid answers.
Van runs fine. Never stalls. Occasionally after being parked, it'll crank but won't start. Power is being cut to the fuel pump. It doesn't prime when the key is turned on. Sometimes you can wait 30 minutes and it's fine, other times it won't start for days.
- Fuel pump was replaced. When it won't start, jumping 12v directly to the pump still activates it.
- a "Newrockies Pro Module" which is a Passlock/Security bypass was installed, so it's not a security/key/immobilizer issue.
- I have a new Fuel System Control Module (FSCM) on the way.
- Replaced all relays and fuses.
Wondering what else I should check.
It sounds like the Crankshaft Position Sensor and Oil Pressure Sensor can cause a power cutoff to the fuel pump?
Just hoping someone has some ideas!
Jason Steady is offline
Old March 14th, 2019, 7:15 PM
Update: New Fuel System Control Module/FSCM installed (Dorman 601-022 which claims no dealer programming needed) and no change. Cranks, won't start.
Old March 15th, 2019, 12:54 PM
Further update:
- If I wire 12v directly to the appropriate terminals on the fuel pump from a spare battery, it runs.
- Checking the fuel pump connector across the pink (ground) and larger gray wire (12v), there is 12v coming in from the FSCM, but when connected to the fuel pump, it doesn't activate it.
There are two additional wires on the fuel pump connector, a purple wire and gray/white wire, both smaller than the pink and gray wires.
Does anyone know what those wires are for?
Old March 15th, 2019, 1:35 PM
mountainmanjoe is offline
Old March 15th, 2019, 2:01 PM
Thanks for the reply! The link doesn't seem to be working for me, are you sure it's correct?
Old March 15th, 2019, 2:08 PM
It's correct. Seems to be down right now. Try this one:
https://www.gmupfitter.com/pages/body-builder-manuals
Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
