87 g20 no rear interior lights - Chevrolet Forum - Chevy Enthusiasts Forums
Old December 6th, 2018, 10:42 AM
Default 87 g20 no rear interior lights
1987 g20 No rear interior lights. Checked fuses in fuse box. Looked for aux fuses behind driver seat. There was fuel tank selector instead. I need to know where the feed for power to the rear lights comes from.
dchamp is offline
Old December 6th, 2018, 6:08 PM
StanVan's Avatar
Is this a stock van, or a conversion?
StanVan is offline
Old December 6th, 2018, 7:41 PM
You want to add rear lights because there are none, or they don't work?
If the former, just run back from the front dome light.....If you are worried about adding to an existing circuit use an led bulb .
My 95 g van was an uplevel model....chrome bumpers quad headlights, power windows and locks...etc. If I remember right there was an over ride switch to turn the rear lights on and off at the back of the van.
canucklehead is offline
Old December 6th, 2018, 9:32 PM
dberladyn's Avatar
From the Fuse Panel Box.
You need to get a schematic for that year. I can tell you on the newer years like mine the positive wire is blue with a white stripe. Orange may also be used. The two colours depend on the intended functioning of the lights.
dberladyn is online now
Old December 7th, 2018, 7:04 AM
It is a conversion with about a foot added to the roof. The lights are controlled by three switches that are mounted in the roof over the console along with a cb radio that is also dead. It's as if there is an override switch or fuse that I can't find. There are dome lights on each side and in the rear that aren't working. Two lights over the console come on when the door is opened
Last edited by dchamp; December 7th, 2018 at 12:15 PM. Reason: additional information
dchamp is offline
Old December 7th, 2018, 12:11 PM
StanVan's Avatar
First, I'd pull that CB out and with a volt meter or a test light, determine if you have power there at all. Also, look to see which direction wires go. This will help in tracing where power comes from.
Is this a custom van, or a camper? Any idea who did the conversion?
StanVan is offline
Old December 7th, 2018, 3:43 PM
Thanks for your interest and help. I believe this to be a Gladiator, no camping eqpt just captain chairs and a couch. There isn't enough spare wire to pill out the cb. Can't tell the direction or color of the wires. Wires to the side lamps are white and black. Wire to the black are dark blue and grey. If becomes necessary to trace wires. I can do that. A schematic for this unit would really be nice. I was hoping someone would say there's switch hidden in the spare tire or such.
dchamp is offline
Old December 7th, 2018, 8:00 PM
dberladyn's Avatar
Well.. it's custom so... it might even have a secondary fusebox. In the modern vans GM provides a high amperage four wire connector for an upfitter to build from. This gives the upfitter negative, battery, run... and possibly one other. It could be the same on yours. The upfitter might have taken that lead and added a fusebox somewhere. Who knows. Good luck.
Old December 7th, 2018, 10:49 PM
StanVan's Avatar
I think it was '85 where they replaced the spare tire switch with technology based on the Turbo Encabulator.
StanVan is offline
Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
