Adding power mirrors?
Old November 7th, 2017, 9:02 PM
  #11
JPM88's Avatar
Default 2008 Chevy Express 2500 Power Mirror Conversion
Hi, thank you so much for your reply. I have a 2008, Chevy Express, 2500, Base Cargo Vab, 4.8 lt., with Power Windows and Locks, wondering what I would need to do to convert to Powered Mirrors. Thank you so much. for your help
Old November 7th, 2017, 11:12 PM
  #12
canucklehead's Avatar
https://chevroletforum.com/forum/exp...-switch-74249/
Pull off your door panel on the drivers side and see if the wiring is there......also read this conversation
Old November 16th, 2017, 12:26 PM
  #13
cablesplicer's Avatar
I just brought nice frount & side doors from junk yard for my 87 g30 bucket van and they have elec. Mirrows / windows. I need to change the windows with my crank ones. I plan to look into wiring the mirrows up and i will post what i find works [or doesn't work , lol]. This will make a good winter projech. I am a contract telephone cable splicer so i have no fear about diving into this. The wourse could happen is to put my old mirrows on [lol , i hope]. Good luck and enjoy the adventure.
Old March 2nd, 2018, 4:30 PM
  #14
Woolywoop's Avatar
Default do yo have tried to connect your power mirror?
I my friend i want to know if you have tried to replace your manual mirror for powerd mirror, i want to do that but i search if is work before. can you help me with that?
Old March 2nd, 2018, 5:20 PM
  #15
StanVan's Avatar
It can be done, but the switch is extremely difficult to find (I'm told).
Old November 14th, 2019, 1:45 PM
  #16
VP2019's Avatar
The Express van power mirror switch is easy to buy, and costs less than $25 online
GM part # is 20945027
It's also sold as an AC-Delco part.
The small plastic trim piece that the switch fits in is another matter.
GM only sells that small plastic trim piece as part of a larger assembly that includes window switches, door lock switch and the mirror switch.
Old November 15th, 2019, 5:30 PM
  #17
Trackvw's Avatar
is the switch a standard GM part that will be on Sedans etc
Old November 15th, 2019, 9:41 PM
  #18
VP2019's Avatar
No. Switches typically don't interchange between different GM models because they are different cosmetically.
This one is specific to the Express/Savana vans.
See attached image.
Old November 21st, 2019, 6:04 PM
  #19
William Kisselstein's Avatar
You can probably just drill a hole in the plain panel section. It snaps off.
Old November 27th, 2019, 8:53 AM
  #20
Rsimon0303's Avatar
Does the switch control the top and bottom mirrors?
Quick Reply: Adding power mirrors?
