Anyone Switch from Suburban to Express?
#21
You might want to check your differential. You may not have limited slip. The easy way to check is to look at the RPO sticker on the passenger door. Look for "G80". I had concerns, and started this thread to research it.;
https://chevroletforum.com/forum/exp...rential-88338/
Eye opening.
Eye opening.
#22
BTW, I mentioned that we get around 14 mpg mixed use... that's city/highway combined, not towing. We get around 7.5-10 mpg when towing our 7k+ lbs travel trailer, depending on speed, hills, wind, etc.
- Here's the last row, row 5... (we've since removed this row to accommodate more storage.
- This is everything forward of the last row. We actually moved the 2-seat frame from the last row and replaced the left single seat with it. Now there's 3 seats across row 4.
#23
VinzClortho (March 19th, 2021)
#24
Agreed. You can see the bolt heads at the base of the seat frames in the pics. The 2-seat frames use 6 bolts and the single-seat frames use 4. They are heavy to remove from the vehicle (a second person makes it easy, though).
Aolson6
Express & G-Series Vans
12
February 16th, 2021 11:20 PM
mggarner@gmail.com
January 10th, 2021 2:26 PM
