Brake Fluid black again
I took the Van for a “complete” brake fluid flush. They showed me the used liquid (like half of a bottle) black as a coke, and then the new one in the reservoir.
I lasted 1 week after is all black again as a coke. Any thoughts? |
decomposing rubber brake lines.
(Post 427960)
Replacing lines before another flush. Thanks |
even if you have bad lines they should go black that fast......im sure they just changed the fluid in the master cylinder.........a full flush will be a lot of fluid exchanged...more than 1/2 a bottle especially if you have anti lock brakes.......ive flushed brake fluids on many vehicles and youll need close to 2-3 quarts....
Originally Posted by loopedr1
(Post 427989)
have you though about changing the fluid your self......its not that hard.....just a little messy and time consuming if you dont have the correct tools.....
(Post 427997)
Hope this brakesystem has only DOT3 brakefluid in it.
In my mind, a friend of mine had years ago a problem like this. He went to shop and they hadn`t DOT3 and he took DOT 4 or anything else. Shop said DOT4 is better than DOT3 and he filled this fluid. In Germany DOT3 is not so common, I think we use more DOT4 or 5. Time later problems with brakesystem including black brakefluid. It was so black that we named it fluidcoal. A jamglass full of this and You were not able to see very little light when torch should light throu. A third vanner said we found the stuff, where black holes in space made from.....:) End of all, we had to flush hole system with brakecleaner and replaced a lot of rubberthings in main + wheelcylinder and all rubbertubes on axles. By the way, last week I manual flushed my 95 G20 4 wheel antilock and it`s took about a quart to have clear output of wheelcylinder + pumpmodul-bleeder. Good Luck... |
AFAIK, DOT 4 and 3 are compatible, not DOT5.
Nevertheless, last time they used DOT3, no brand (Or at least I cant remember) but DOT3. |
