Chevrolet Express G1500 1999, 5000cc V8 no start
Old September 18th, 2017, 7:43 AM
Newly Registered
rogarc1's Avatar
Default Chevrolet Express G1500 1999, 5000cc V8 no start
my vehicle after a few days in the paint shop does not start, just a wash and a pressure down and after that do not want to start, first had error in the sensor of the crankshaft (P0336 and P0339) changed the sensor and now gives errors.
It turns on perfectly after disconnecting the battery for a few minutes, then the fuel gauge goes to the end to the right and then turns off and does not turn on anymore, only when it redials the correct gas level, but to few minutes it goes turn off again.
and change the relay of the gas pump, check cables and I still do not find the problem
Old September 19th, 2017, 12:12 AM
canucklehead's Avatar
Did you get water under the dizzy cap? Camshaft position sensor is in there.
