Chevy G20 1989 Headlamp type?
Hi, I live in the UK I'm really interested in replacing my old dim headlamps with some nice new ones. I have a 1989 Chevy G20 Starcraft Conversion Van and I've been looking at doing a HID conversion with the Halo sidelights built in.
My problem is that van is currently stripped down and getting the bodywork sorted before getting a spray job and I have mistakenly thrown the old lamps so I cannot get any info or sizes from them.
I've been googling and ebaying to see what I need, but the more I look the more I get conflicting vehicle compatible information and different size information. It's the model with headlights above each other. I think the size is 165mm by 106mm? But most sizes seem to be given as 165mm x 100mm or 6 x 4 or 4 x 6?? Not sure what to buy.
I've found this on ebay.com item number 330952813665, which would be ideal for me and just what I'm looking for but the more I look at similar products on ebay most say they wont be compatible...! I would like to go with these but I'm not convinced they will fit and with the shipping to the UK and returns will be costly and time consuming.
If anyone can point me in the right direction for the correct size or any model numbers to be able to check with.
Thanks John.
Thanks John.
if you can pull up autozone.com put in a USA zip like for Las Vegas NV you can use 89115 zip code will come up with the headlight choices like if it is a single or a duel headlight system
Headlight | 1989 Chevrolet G20 3/4 ton Van 8 Cylinders H 5.0L TBI | AutoZone.com
farfarsson
Express & G-Series Vans
September 9th, 2013 4:58 AM
lcfake
August 14th, 2011 5:06 PM
