Cleaning 1997 G-3500
Old June 13th, 2019, 1:17 AM
  #11
Chris S.'s Avatar
Exactly. It took a some elbow grease to remove the glue from the vinyl.
It's cut to fit so it works fairly just laying there. I have some work to do, but when I'm done I'll just use more carpet tape to stick it down.
Did you use the OEM floor as a template to cut your plywood or a different method?
Old June 13th, 2019, 2:39 PM
  #12
No, because the OEM floor doesn't go edge to edge. It only reaches the plastic trim paneling inside. (Mine is a passenger model). I wanted the wood to be tight, to have as little gap as possible.
I stuck together some sheets of carboard from work to cover the entire floor, and made a template which I then transferred over to the plywood, which is 3/4" exterior grade sheathing TNG (tongue-in groove). 5 ply I think.
