crank no start issue
Old August 24th, 2017, 2:43 PM
shaggenwagon93's Avatar
Default crank no start issue
hey guys I got I 93 Chevy v8 van here been working on getting it started for about 3 yrs
I've put a brand new ignition system and fuel system in it still no start I'm getting spark I've replaced the following parts
starter
battery cables
tbi
fuel pump/strainer
fuel sending unit
ignition coil
distributor cap &rotor
spark plug wires
spark plugs
map sensor
any ideas would be helpful I'm just stumped here
Old August 24th, 2017, 3:47 PM
kevinkpk's Avatar
Is it have a check engine light? What color is the spark?
Old August 24th, 2017, 11:13 PM
StanVan's Avatar
Compression?
Old August 25th, 2017, 6:51 AM
yes check engine light is on. spark is good bright white color. thinking maybe a sensor ecm? pcm ?
Old August 25th, 2017, 6:53 AM
ya its low on compression in some cylinders but no total loss of compression. You think low compression could keep it from starting though?
Old August 25th, 2017, 7:51 AM
Twscarp's Avatar
starter
battery cables
tbi
fuel pump/strainer
fuel sending unit
ignition coil
spark plug wires
spark plugs
map sensor
Is the fuel pressure good? Will it start with a shot of starting fluid?
Old August 25th, 2017, 9:11 AM
StanVan's Avatar
A severe lack of compression might suggest, among other things, a broken timing chain.
Old August 26th, 2017, 4:29 PM
ya I hope its not I really don't want to take apart or replace the engine
Old August 26th, 2017, 4:30 PM
haven't tried starting fluid
Old August 26th, 2017, 4:56 PM
kevinkpk's Avatar
That will eliminate it to the fuel system, you really need to determine what the check engine code is
