electrical issue with van
Radio didnt turn off after turning van off and taking key out until puttin key back in and turning ignition slightly and off again then another day tail lights wouldnt turn off until shifter was moved then the interior light inside back doors wont shut off. helppppppppppp...........1992 chevy g20 conversion van
okay. the first one is kinda common. Once the contacts and actual teeth in the ignition switch wear down over the years you can actually shut off the vehicle, but leave it on acc and take the key out. I have done this before.....Just wiggle the ignition switch a bit to centre it when turning the car off.....I would live with that before messing around replacing the switch.
The second one sounds similar. The gear switch is a cable....make sure its adjusted properly. Was it tail lights or brake lights? A sticky brake light switch could also explain if the latter... The interior lights have map light switches on each side....I bumped my head on it once and bumped the map light on.....but if its the centre cargo light....maybe a bad door pin....or the headlight switch got moved all the ay to the right to turn on the interior lights by mistake..... Check all those little things.... I hope I have helped.... |
