Rear Heat Stuck On 2003 Express
Old April 14th, 2024, 3:12 PM
03 Express's Avatar
Default Rear Heat Stuck On 2003 Express
Hi, I have a 2003 Chevy Express 1500 with rear ac/heat. It’s a conversion van with pro-air rear climate control. The rear climate control worked well until yesterday when it was stuck in heat mode. I noticed under the van is a coolant control valve (picture below). Is there a way to test this? Is there also a blend door? Thank you!
Joe
Old April 14th, 2024, 9:58 PM
if that's a picture of your control valve then it's vacuum operated. Apply a vacuum and see if it opens. The vacuum is probably controlled by a another solenoid though and those usually burn out. As for your rear hvac it's might be aftermarket done by the conversion company.
Old Yesterday, 8:32 AM
03 Express's Avatar
thank you for the info. I’ll pop the connector and apply vacuum. I’ll also see if vacuum at the connector changes based on heater setting.
bcpaul
March 29th, 2024 6:27 PM
Skyhawk1961
July 29th, 2023 7:25 PM
dberladyn
June 25th, 2021 10:40 AM
Skipp1962
February 1st, 2021 5:35 AM
Ireland
February 16th, 2011 2:46 PM
Quick Reply: Rear Heat Stuck On 2003 Express
