Express 2500 05, oil pressure dropped
Was driving my van and suddenly, heard a knocking noise and oil pressure dropped to zero. Replaced oil, oil filter and oil pump. Pressure didn't recover and noise still there, any insights? Ideas?
Please help. |
Oil pressure is not created by the oil pump it is created by bearing clearance. You have spun a bearing and need a new engine. Once an engine is knocking it is finished
Let me guess... no previous problems, then one day your engine automagically lost 3 qts of oil without smoking, obvious leaks or blowing a gasket? More than one person has had that with the 5.7L... what engine is in yours? How much oil was in it when the problem occurred?
On mine, it was the #1`rod/main bearing that spun. I did buy some time by installing oversize bearings every few weeks but it didn't take long until it was beyond even a .060 bearing doing any good. Yep - if it's knocking, it's pretty much toast. 5.7L's also seem to have a problem w/ wrist pins - they go bad & then that rod hammers out the rod bearing on the crank. Remember when all you needed to fix a 350 was some duct tape & a hammer? |
