Notices
Fixing turn signal lights - 1995 Chevy G20 Van
Old October 29th, 2018, 10:05 AM
Default Fixing turn signal lights - 1995 Chevy G20 Van
Hey so this is the second place I've made this post cause I can't find the other one, so I decided to make a new one, cause I don't know if the old one went through or not. Alright so moving on: I turn my hazards on, hear the clicking underneath the dashboard, and the lights all around work and flash. My backup lights work as well. Now I've already replaced almost ALL of the fuses, I replaced the turn signal SWITCH underneath the steering wheel, and I replaced the bulb sockets and bulbs in the back. Turn signals still don't work. So after some research, I've come to the conclusion that maybe its a switch/relay/flasher problem. So I went down underneath and pulled the Hazard/Turn signal flasher, and tested it with a fuse tester. It's green and apparently in working condition. So now I'm confused and don't know what to do next, any suggestions? I really want to get these working cause I'm in Florida, and the cops here are jerks.
ChevysOrDeath is offline
Old October 29th, 2018, 11:49 AM
StanVan's Avatar
No one state has a monopoly on jerky cops. Just sayin'.
Not sure about this, but I don't remember the turn signals and hazard lights using the same flasher. I have been wrong before, and I'll be wrong again.
StanVan is offline
Old October 29th, 2018, 6:33 PM
Location: Currently the Candian Gander is wintering over in New York.
I'm kind of with StanVan on this. Usually there are two flashers. The Hazard flasher will turn on all flash-able bulbs, while the Turn signal flasher is designed to flash one side of the vehicle, so it is a lighter duty unit. My truck is a 1981, and that is what I have. One fuse feeds the hazard, turn, and stop light circuits.
If you have an owner's manual, the location of the flashers should be available to you.
Kazoocruiser is offline
Old October 29th, 2018, 9:51 PM
"where is the turn signal flasher on a 1995 G20"
This video might help.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
