Notices
G10 van stops running
Old June 8th, 2019, 8:51 AM
Default G10 van stops running
Hello- I have a 1979 Chevy G10 with a rebuilt 1994 350 engine. It runs for 5 minutes then the fuel pressure drops to zero and it quits. I have tried running it with the gas cap off thinking it was a venting issue but no luck. Any ideas? Thanks Rick
Rick Taylor is offline
Old June 8th, 2019, 9:21 AM
dberladyn's Avatar
fuel pump?
dirty fuel filter?
pinched fuel line?
carburetor issues?
dberladyn is offline
Old June 8th, 2019, 9:45 AM
I read on another forum that the fuel filter can fill up with crud from the gas tank, have to replace my tank maybe?
Old June 8th, 2019, 3:20 PM
I'm here for the party
Irish_alley's Avatar
does it start right back up or does it have to sit for some time?
you said a 94 but did you keep the tbi or put a carb on it?
Irish_alley is offline
Old June 9th, 2019, 7:42 AM
I have a carb on it and a fuel pressure regulator running at 5.5 lbs of pressure. The pressure drops to zero as it starts to die. I have to wait about 15 minutes before it will start again. Also seems to quit mostly when going uphill.
Old June 9th, 2019, 9:32 AM
StanVan's Avatar
Electric or mechanical fuel pump? If the pressure is dropping, it seems to me to be a fuel delivery issue.
StanVan is offline
Old June 9th, 2019, 6:07 PM
Electrical. I can't imagine it would run for a while than stop, but maybe?
Old June 10th, 2019, 9:57 AM
StanVan's Avatar
It could if it's going bad.
StanVan is offline
Old June 14th, 2019, 8:09 PM
Any idea as to what I'm looking at here? Did not have this on my old engine. Thanks.
Old June 14th, 2019, 8:25 PM
thats a fuel pump filter and pump
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
