G30 3500 turn signal and brake light
Old July 17th, 2019, 2:06 PM
jeremie tessier's Avatar
Default G30 3500 turn signal and brake light
Anyone can give me tips at what to look... turn signal and brake light stopped working at the same time. Fuse are good and day light is working (front and back). first thought is the relay. But why would brake light be affected? could a burnt bulb cause this kind of issue (no more turn or brake light front and back)?
thanks everyone
Jeremie
It's a camper based on a G30 1985
Old July 17th, 2019, 4:47 PM
How did you check the fuses? A visual check is not good enough. A fuse can control more than 1 thing and may not be marked as you think it should be.
Old July 17th, 2019, 4:49 PM
loopedr1's Avatar
a burnt bulb usually only affects on corner of the vech......like left front or left rear.....but not all the way around....i would look for a bad ground wire or broken wire....you could also have multiple issues at the same time.....bad ground...bad brake switch.........good luck
Old July 17th, 2019, 11:11 PM
ChevyVanMan's Avatar
thanks everyone
Jeremie
I believe all of them go trough the turn blinker switch too. Make you have the right DC coming out of it.
