Help with shock absorbers
Old July 27th, 2017, 3:52 PM
Berginc4's Avatar
Default Help with shock absorbers
I have a 2010 Express Passenger van RWD 2500 135" LS. It seems like the only heavy-duty shock replacement is the Bilstein 4600. Any reason NOT to install these?
Old July 28th, 2017, 9:01 AM
Twscarp's Avatar
Gabriel and Monroe also make Heavy Duty shocks for your van. The Bilstein's are three times more expensive than Monroe's, not sure if they are worth it. I use Monroe's, but my van is a 2008 1500, that is not used for heavy duty hauling.
2010 CHEVROLET EXPRESS 2500 4.8L V8 Shock Absorber | RockAuto
Or try GM shocks, will have to check for exact shock for your van.
https://www.gmpartsgiant.com/parts-l...ion-front.html
https://www.gmpartsgiant.com/parts-l...108f9a3bffda65
Old July 28th, 2017, 4:06 PM
I also use Monroe shocks. I have used Bilstein and have not had good luck with them. Better bang for your buck with Monroe!
