LED headlights
Old November 12th, 2018, 1:49 PM
  #41
KONNMAN's Avatar
I have installed 5x7 Autopal headlights and the cutoff is like OEM and I put LED bulbs and havent had any issues.
They are clear glass.
https://www.ebay.com/itm/200mm-H6054...cAAOSwu4BV05N2
Old November 12th, 2018, 2:40 PM
  #42
I think the factory spec headlights are engineered specifically to be as bright as possible without blinding everybody. When you need more, you turn on the high beams.
LEDs usually have ****ty spectral distribution (bad color) compared to halogen too.
Old November 12th, 2018, 2:47 PM
  #43
Wow they are actually blue.
Their website is pretty funny.
Amaging Performance
Enhanced Light output
Elegance of blue lamp with light output of clear lamp
HID Colour Simulation
Higher Colour Temprature
Perfact White Light
Autopal
So is there a gasket to keep moisture out?
Old November 12th, 2018, 10:55 PM
  #44
silent_20's Avatar
I had to cut some of the plastic to make room for the heat sink of the LED. After I had it install you can tell that the light needed to be adjusted down. I like how bright they are and also the color.
Old November 12th, 2018, 11:41 PM
  #45
Originally Posted by silent_20
to the van with Halogen lights. It looked to dim
Don't forget that halogen lamps (and LEDs too) dim with age, so it could have been time to change them. In your photo they look totally pooched.
Old November 13th, 2018, 12:31 AM
  #46
silent_20's Avatar
I underexposed the picture to capture the hotpots better. Both of them had more light spill.
Old December 19th, 2018, 9:40 AM
  #47
GeneveConversionVan's Avatar
So I instelled the LED bulbs, they are really bright, and install was fast and easy.
But.... I got the finger from drivers in front of me at night with low beam. High beams were great as everything was lite up, but drivers coming my way, and the drivers going in the same direction i was going, in from of me, gave the finger.
I think they are too bright and not properly aligned, but how can I adjust light aim?
Old December 19th, 2018, 11:21 AM
  #48
StanVan's Avatar
Find a building or wall on level ground you can pull up close to. Using tape, mark the top of the beam. Back off 50 feet or so, and if the beam is higher, they need to adjust down. There are screws on the housing to adjust them.
Old December 19th, 2018, 11:55 AM
  #49
silent_20's Avatar
From my pictures you can see that I had to adjust the beam a lot. I haven't had anyone flash me or honk at me because of the headlights. I haven't bought the high beams but will once they go on sale.
Old December 19th, 2018, 11:57 AM
  #50
OK Thanks Stan and Silent, will try that.
Quick Reply: LED headlights
