Notices
LEDs and Hyperflashing.
Old October 13th, 2018, 8:20 PM
Default LEDs and Hyperflashing.
So what have you done folks with LEDs in old Express?, installed a resistor or a new LED friendly flasher? Before buying either want to know what actually works.
GeneveConversionVan is online now
Old October 13th, 2018, 9:44 PM
StanVan's Avatar
I don't know about the '01s, but the newer ones don't have a flasher relay. All you'll need is the resistors anyways. Resistors put the load back into the equation to make the original relays work. Or, you forgo the resistors and replace the relay. You don't need to do both resistors and the relay. But here's the catch; If you go with resistors, you can't go back to regular bulbs if something happens, and you can't get LEDs. But if you go to an electronic relay, you can. Those electronic relays work with both LEDs and regular bulbs.
On my '16, they fool you. Lots of electronics. No relay. It has a "Body Control Module", that controls flashing, produces a sound that gets pumped through the left door speaker, that mimics the sound of a flasher relay. It took me 20 minutes to find the sound coming from the effin' door speaker.
StanVan is offline
Old October 13th, 2018, 9:53 PM
Good old days u?!!!
I do have the relay, and I agree, If something happens I can go back. But I have read in Amazon reviews that the relay for LED wont work.. Just wondering if anyone here has tested both ways.
Old October 13th, 2018, 10:09 PM
StanVan's Avatar
With the correct relay, it will work without resistors. Standard relays use the load of the bulbs to make it flash. That's why the flashing goes nuts when a bulb blows out. Try this link for more info;
https://www.superbrightleds.com/cat/...oad-resistors/
StanVan is offline
Old October 13th, 2018, 10:58 PM
Great link, thanks!
I wonder what I will get once I replace the low/high beam with LEDs...
Old October 14th, 2018, 8:10 AM
This outfit is installing projectors and HIDs in Express/Savana headlight assy. https://www.sickhids.com/gm?lightbox=dataItem-jm11s0p6
It's just shy of $600 for a pair (all new parts), you can DIY it for less than half but it is a lot of work to seperate the headlight housings (without damaging) and reseal them. TRS https://www.theretrofitsource.com/ sells high quality DIY kits.
LCAC_Man is offline
Old October 14th, 2018, 11:18 AM
My 01 has this type of headlights, I dont think those will fit as the are for 03-on
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
