No Low beam headlights
Hello, I have a 1994 g20, the high beams and fog lights work fine but both of the low beam headlights do not work and nor do they have power going to them, I tested with a multimeter while they were on. Could it be a bad relay? And if so where is that located at so I could the good ol shake test and or replace it. I just received this van I am not too experienced with the electronics side of it.
When I get in (2-3 hours) I'll post wiring diagrams from Clymer. Separate sealed beams (side-by-side) design may be on a separate fuse.
Ok, here's everything I got for '94 G series models
https://cimg4.ibsrv.net/gimg/chevrol...64b0c40027.jpg https://cimg6.ibsrv.net/gimg/chevrol...18a64bd6e7.jpg https://cimg0.ibsrv.net/gimg/chevrol...80d8664de2.jpg https://cimg2.ibsrv.net/gimg/chevrol...9d9e6674e9.jpg https://cimg4.ibsrv.net/gimg/chevrol...ecba752c27.jpg https://cimg6.ibsrv.net/gimg/chevrol...54e15ea7e4.jpg Hope something in there helps. |
Does anyone know where the daytime running lights relay would be or the fuse going to it?
https://cimg2.ibsrv.net/gimg/chevrol...d98acbe4b2.jpg
There's the basic fuse box behind brake pedal (my '93). If not there in the '94 check under driver seat. Don't know about the relay off-hand. You might have an under hood relay box also. |
Thanks you I did solve the problem, bad ground connection. Thank you for all of your help I really appreciate it and I'm sure those pictures will come in hand later :)
Good to hear. Stay safe.
