P300 misfire code. Need expert help!
#11
if it won't misfire when floored or shortly thereafter...its probably not cats...that is when the backpressure is highest.
p0300 random misfire...."random" means it can't identify which cylinder is misfiring not an intermittent condition. ...but if you go into misfire data...the offending cylinder counter stores it.
#13
#14
I'm leaning towards bad injectors...
I was going to run an injector cleaner through the tank and monitor my fuel trims.
#15
haven't replaced many injectors on chevy's... they are usually pretty good....if its not misfiring under full load, I doubt its injectors. Wot is when the fuel demand is highest....the fuel trim would be adding to it adaptive limit 30%. Lean misfire would show lower post cat 02 voltage readings. ignition misfire would should high post 02 voltage reading.
gm has an active fuel injection tester that measures injector balance. injector cleaner through the tank won't do much if anything for a plugged injector.
#16
#19
Ok. So I just swapped injectors from one of the misfiring cylinders to the good one. No change.
Could a leaking intake manifold gasket be the culprit?
To recap: the misfires occur on the same 4 of 8 cylinders at highway speeds, or revving above 2000 rpm in park.
There is no misfires at idle and no difference when spraying carb cleaner around the intake.
#20
Did you eliminate all the causes in the link for P0300 I posted?
