Power stays on after door opening
I have a 2004 Express 1500 AWD cargo van that has just recently started having a problem with the power to the accessories staying on after the door has been opened. I can get the accessories to turn off by repeatedly cycling the lock switch ( It has pwr locks and wdws). It drained the battery the other day, as my wife used the truck and didn't realize the accessories were still on. I just replaced the battery as it was getting to the end of it's service life not due to this problem. Is there a switch inside the door that acts as a door switch? There is nothing on the door jamb like the old school pin switches. Something tells the body computer that the door is open, thus cancelling the retained power. Thought I'd ask before tearing apart my daily driver. Thanks, Kevin.
I researched the problem, ordered a new latch switch, and replaced the switch. That was a PITA! But the problem persists. I can get the raido and accessories to turn off if I play with the door handle, or cycle the lock switch. But it is very erratic. Next suggestion? The passanger side works like it should so I think I can eliminate the body computer. Maybe too much play in the actual latch assembly? Wiring looks good, no evidence of anyone ever having the door apart before. Frustrating!:confused:
Did you ever get this figured out? My 06 3500 is having the same problem. Thanks
Brew |
Originally Posted by tsbrewers
(Post 257535)
Brew |
Thank you, I appreciate it.
Brew |
