Rear AC hose and lines
Hi and thanks
No, I want to replace it.
And i wonder if the part on the picture is what sits on the car.
There is nothing on GM parts like this.
But the summit says it is for the undercarriage of the car
I have a leak on the pipes under the car and intended to order this part
my wonder is if all Chevy with orginal rear ac has this pipes or it differs between the different converson companies
Kent
Kent
Do you have to replace the whole thing? Couldn't you just repair the leak, or replace a short section?
Well if you have to lift it for a small section, the you have to lift the body to replace the entire thing right? If he's lucky and it's in an accessible spot, the repair might be easier than complete replacement.
Hi
I don't think so, the leak is behind the right front wheelhouse probably in a hose or splice the car is in winter storage so I find it hard to access it thought maybe someone had a picture undercarriage and maybe have replaced the part.
kent
kent
