Rear brakes locking up
have a 2007 Chevy express 3500 passenger van. 100000# towing capacity. I think it is called a brake proportioning valve or metering valve to help direct pressure to the back brakes. It is located on the driver side frame. It has an electrical connection with one brake line and on hose connected to it. Looking to see what the correct name is so i can get a replacement one.
My brakes on the back just started to intermittently lock up whether towing or not. replaced both rear calipers. bleed brakes put on new brake booster but has not fixed the problem. any suggestions. thanks. |
Originally Posted by Wde
(Post 497711)
(Post 497711)
Dyanamic Rear Proportioning (DRP) is controlled entirely by the ABS system. No dedicated valves. |
(Post 497711)
Failed flex lines can also cause brakes to drag. Or possibly a malfunctioning parking brake. |
