"Service Stabilitrac Soon"
This is a new one. I've had the message before, and upon research,it can happen when you use one of those Bluetooth OBDII devices (like I sometimes do). I unplug it, plug it back in and it works just fine. A known anomaly.
But it happened twice, yesterday and today, and I wasn't using the OBDII thingy (technical term). I plug up the OBDII device, scan for codes with Torque Pro, and no codes. I shut the engine off, restart, and the message goes away. Anybody else have this happen? Any ideas on what it could be? |
Originally Posted by StanVan
(Post 356635)
Happens when your too quick in a turn, spin tires etc. Stop turn Van off for 30 seconds restart..
There might be some clues here:
https://chevroletforum.com/forum/tah...control-45015/ |
By the way it is in the manual too :-) Wait to you engage engine braking.!!!!!!!!!!
One of the times was in a parking lot, and I had just clipped a curb, and probably spun the wheel a bit. When I first had the van, I did spin a wheel one time getting into traffic, and it didn't give the message.
Won't do it much, just certain situations. My GMC 2500 did it once on a gravel road.
Happened again, in the driveway, backing it from the front into the back yard. I'll try a reboot tomorrow.
Okay, that was scary. Never done a reboot before, and when I went to start it afterwards, it had to "think" about it. Second start was fine. I'm off to run errands. I'll report later.
Reboot ?
