Shaking steering on a new express van 2500 2017
I have cargo van express2500 year 2017
30,000 km shaking steering loosing control
The dealer said that every thing normal but they dont find the problem .
i own a bunch of 2500 vans and they are prone to steering wobble..... if you crest a small hill they will wobble or if you stab the brakes they will wobble......it is usually caused by the steering center link twisting and causing the tires to pull in and out and the fight each other trying to get back to center....the link twisting is caused by worn or loose idle arm and pitman arm joints.....look for those to be your problem....also check your toe on your alignment......that with worn joints is a recipe for the infamous steering shake....
