Transmission Cooler
Old October 29th, 2018, 1:56 PM
Ron6519's Avatar
Default Transmission Cooler
I'm installing a separate transmission cooler on a 2001 savanna van. Which of the two cooler lines( top or bottom) into the radiator is the return line?
Transmission is not in the van.
Thanks
Ron
Old October 29th, 2018, 4:22 PM
The one that's cooler to the touch :P
Old October 30th, 2018, 7:04 AM
LCAC_Man's Avatar
you haven't posted enough info...do you have a 1500, 2500 or 3500? they have different transmissions..
Old October 30th, 2018, 9:00 AM
Ron6519's Avatar
I have the 2500 series with the 4L60-E transmission. Are the lines plumbed differently in the 4L80-e transmission?
Old October 30th, 2018, 9:03 AM
Ron6519's Avatar
As stated in the original posting, the transmission is not in the van. I'm plumbing the transmission cooler in advance of the new tranny going in.
Both pipes are dangling under the van. Both feel the same at this point.
Old October 30th, 2018, 12:20 PM
LCAC_Man's Avatar
4L60e pressure/outlet is the lower port, it would go to the upper connection on the radiator.
4l80e pressure/outlet is the front port.
Old October 30th, 2018, 1:49 PM
I'm just kidding.
Old October 31st, 2018, 4:11 AM
The top one should be the return line. Plumb your cooler in there.
Old October 31st, 2018, 8:32 AM
Ron6519's Avatar
Looked in the GM Service manual and they have the additional transmission cooler plumbed from the bottom line for the 4L60-E transmission.
File Type: pdf
Old October 31st, 2018, 4:33 PM
I've seen that diagram too. It's wrong.
The cooler is filled from the bottom to prevent aeration, and the makers of the aftermarket coolers recommend putting them downstream of your factory cooler.
Quick Reply: Transmission Cooler
