javapower |
July 1st, 2013 8:21 AM |
will not idle .periodic backfiring ,no power
Hey everybody . 1993 g20 100,000 miles 350 , sudden stalling, misfiring ,chugging and backfiring , almost did not make it home 30 miles at 25 mph then 15 last few miles . I found original plugs wires cap rotor were original and I replaced . had ecm tested once and found ok the other kid at oriely said it needs to be tested 3or 4 times to heat it up . I have reasonable spray pattern at both tbi injectors going to check fuel pressure soon had changed filter and verified fuel pump is running . I am getting a code 13 throttle positioning sensor or oxygen sensor ? pick up coil tested fair with my limited diagnostic skills . also replaced coil I am buying the borg warner stuff or what I believe to be the better parts at oriely . Its an old chevy it should not be this hard . currently if I prime it a little and pump gas it will half ass run but not idle on its own . it may backfire and start fire at top of tbi please help this is my big family grocery getter
