4L80E transmission slips in 4th not in 3rd
#11
If you have any questions during your rebuild, just let me know. If you find you have to change some geartrain parts, be very very careful, the parts have been updated a few times and nothing retro fits.
Just wanted to mention that because of the high mileage. Gary
#12
thanks gary, I appreciate your concern. this will be my first rebuild. good thing its on my own vehicle. Do you know if there is a way to replace the overdrive with a higher ratio? I've got 4:11 gears and at 70 mph I'm getting above 2500 RPM. Just wondering if there was a way to increase the overdrive to lower my RPM.
#14
I did something new today. I had a Snap On diagnostic computer connected while driving. The trans did the same problem where it down shifts in to 3rd, then increases the fluid pressure causing 1-2 shifts real hard. Everything resets when the ignition is turned off and back on. Today, I was able to get it to resume normal 4th gear by clearing the code while driving. If there was a way to program the PCM to ignore the code, it may fix the problem and delay having to rebuild the trans for a while. Does anybody know if the PCM can be programed to ignore certain codes?
slownis
September 2nd, 2012 8:26 PM
smith87
February 20th, 2012 2:23 PM
fmlm83
February 11th, 2012 9:35 AM
