Add locking rear axle to express van
I am purchasing a 2020 2500 passenger that did not come with a locking axle. How much of a big deal is this to add and can dealer do this?
Thanks |
It's an afternoon of work, but shouldn't you be asking them?
(Post 457687)
The differential has to be replaced. If you want a step-by-step then purchase a service manual. It's not really territory for a forum.
I'd be interested as well. My van looks to have a 9.5" 14-bolt semi-floater which is likely what you have. That is really more of a three-quarter ton axle even though I have a 3500. It's a bummer because the 10.5" 14-bolt was much easier to work on. Also most of the aftermarket books seem to be geared toward pickup trucks and say that the 14-bolt semi floater wasn't made after 2013. I think I would like to get a TruTrack (because it is an all gear limited slip) but our application isn't listed. The Gov-Lock (G80) could likely be found at a dealership online. You don't need to do a full setup of the gears as the pinion isn't getting messed with. You just need to set the backlash and carrier bearing preload.
Originally Posted by Triaged
(Post 457714)
| All times are GMT -5. The time now is 4:34 AM. |
