Anti Theft System Triggered, won't start
Old June 15th, 2022, 7:37 AM
  #11
wyn_fox's Avatar
I just went through this problem and tech said he had to reprogram security. Started up fine when done..
Old August 18th, 2022, 1:10 PM
  #12
oceanfront's Avatar
I have a 2011 express 1500 and just yesterday the anti theft light came on and truck won’t start or crank. Tried all methods to bypass nothing worked. I even got a new key from Chevy dealer with no luck. Light stays solid on with no crank
Old October 19th, 2022, 12:44 PM
  #13
funtwodrv's Avatar
Did you resolve this issue? I have the same symptom with our 2014...
Gary
Old June 7th, 2024, 4:45 PM
  #14
Luckylove's Avatar
need your help! we have a 1998 chevy cheyenne c2500hd. my man was changing the ignition lock cylinder and noticed that the wires broke off at the connector where it plugs up by the ignition lock cylinder. the way they broke off kept them from being able to be spliced back to the connector. this set off the passlock security system. he tried to bypass the system using a resistor. it cranked and ran fine last night but now today nothing. the radio will come on but he is not getting 12 volts to the ignition. no dash lights come on...nothing. i plugged the scanner up to the truck and when it test each system they all say not installed. the scanner cant even detect the systems on the truck. any idea what they problem is?
Old June 7th, 2024, 5:02 PM
  #15
maybe try replacing the broken part, instead of reviving every ancient thread on this forum?
rjal
December 26th, 2020 9:00 PM
ofer
June 29th, 2019 9:58 AM
dan83
March 17th, 2017 7:50 PM
2kingof1dasouth4
May 29th, 2013 8:41 PM
diallom8
September 9th, 2012 5:48 PM
Quick Reply: Anti Theft System Triggered, won't start
