Express 3500 Radio
Express 3500 Radio
I have a motorhome that is built on a 2000 Chevy Express 3500 frame. The previous owner installed an after market radio. I want to replace it with a factory radio. I have one from my sons Lumina. Is there anything special I need to do to re-installl the factory radio?
depends on what the previous owner did when they installed the aftermarket stereo. If they used a harness to connect to the factory wiring, and didn't hack it all up, then no, there is nothing special you need to do. if they did hack up the factory wiring, then you will need to buy a vehicle side harness to connect to the radio.
Yes. Buy a new vehicle......lol
Gm has the stupid theftlock bs on their factory radios because they are sooooo often stolen....
If you are going to install a gm head unit, call a dealer first to see what is involved in them resetting the passcode or whatever.
In my opinion, aftermarkets are nicer, cheaper and have more options. Unless you really want that factory look...I would not bother.
True, probably cost $50 to get reset at the dealer. or you can watch a few youtube videos on how to "fix" it so it works. Basically involves removing a chip inside the radio. Might be worth a quick try though to see if it works, not sure if the older ones had the theft feature too.
All the after market radios I've looked at have buttons that are to small and I can't read whats marked on them while I'm driving (old and need glasses to read with) so I want to replace it with the factory radio so I can change stations while driving.
Really. I have a jvc double din size deck, and the buttons are large and there is only one **** for volume. Very simple layout.
I guess you will have to decide. I have the factory 6 disc gm radio in the wife's hhr, and its nice. Matches the dash perfectly....
Good luck.
Good luck.
Pierre
May 14th, 2012 1:50 PM
daycaremom
April 22nd, 2012 11:46 PM
adamant
February 15th, 2009 8:49 AM
closekutt
August 26th, 2007 11:38 AM
warrennaujalis
October 28th, 2006 10:24 AM
