Elvis56 |
March 22nd, 2017 6:40 PM |
2008 Tahoe rear power liftgate question
Hello, I have scoured the forums looking for an answer to my issue, which is quite common mostly. My rear power liftgate will not open, it will not respond to the remote, the interior button, or the button on the liftgate handle. It will not even open manually when it's shut off on the interior lockout button. It also does not make any noise, other than the relay in the engine compartment. The lights flash like its gonna open but does nothing. Backup park assist works fine so fuse is good. Information screen shows ' rear access door open' . I have drilled a hole in the trim panel near the latch to open the door and then shut it and still nothing. Rear window opens. I have opened and shut that a few times to be sure that's not causing it. It seems that nothing is getting power there. Struts are not the problem as they were replaced in the last year. Anyone having this issue? Most of the issues that people have that I have read at least can hear something happening at the latch...thanks.
